converting the format of audio track in AVI file - plz help
anfjavid
Contributor
Hello guys, i have a video file whose audio track doesnt play properly in my media player. The audio track is mp3. Now i want to convert it to aac or ac3 or mp3 with a different parameter without losing the quality of the video track. In other words the video track should remain the same but the audio track should be in a different format as said supra.
Plz suggest a software which can perform this job without a hitch...
thanx in advance
Welcome to virtualdub.org! - virtualdub.org
- Load the video
- Under Video select direct stream copy
- Under audio select full processing mode and then select compression
- Select the format and bitrate, quality settings, etc
- Under File -> Save as avi
Make sure you have the necessary codecs before beginning, though (Free-Codecs.com : Download K-Lite Codec Pack 7.6.0 FULL, K-Lite Codec Pack 7.6.0 STANDARD, K-Lite Codec Pack 7.6.0 BASIC : K-Lite Codec Pack is a collection of codecs and related tools)
