Cooler Master has announced a new chassis that comes in LAN box form factor and doubles up as a test bench called HAF XB.
The HAF XB is a full ATX chassis designed for enthusiasts and gamers. It provides excellent airflow with two 120mm fans on front, one 200mm fan on top and two 80mm fans on the rear. It also has steel reinforced handles on the side. The outer shell can be removed to transform it into a test bench.
The cabinet has a removable motherboard tray, which makes benchmarking quick and easy. It has 7 expansion slots, supports up to six 2.5" HDDs or SSDs with dual X-Dock slots for mounting hot-swappable 3.5" or 2.5" drives. On the front panel, it has two USB 3.0 ports, two USB 2.0 ports and audio in & out ports.
The Cooler Master HAF XB is now available in the USA and can be expected to launch in India soon. The price in the US is $99 (Newegg) .
