PC Peripherals Cooler Master Cabinet Elite 330 Power Button Problem
daumaster
Contributor
My Coolermaster Elite 330 cabinet has a problem.
The plastic clip at the back of the power switch/button (silver coloured) has broken,so the power button does not come back out once depressed to start the pc.
It is a light blue plastic spring clip held in place with the front panel of the cabinet with two screws.
Where can I get a replacement part asap ?
The design of the plastic spring clip itself is very bad. Chances of breakage again will always be there, unless Cooler Master redeisigns this switch/button with better material.
I doubt you can replace it. Best would be to remove the button itself, and you will be left with a small projection type nob, which gets 'clicked'. And use that to power it.
Yea, it is ugly..but that is the best you could do.
