Cooler Master HAF XB overclocker friendly chassis which was launched few months back is now available in India, it is priced at Rs 8,499.
The HAF XB is a lan box which can be transformed easily into a test bench for overclocking.
Country Manager Of Cooler Master India, Mr.Crane Chen said, “The Cooler Master HAF XB is an innovative product and first of its kind to be made available to the consumers in India. The HAF XB offers features that will fit the requirements of any end-user looking out for a performance oriented, feature-rich chassis for their gaming and overclocking needs”
It provides excellent airflow with two 120mm fans on front, one 200mm fan on top and two 80mm fans on the rear. It also has steel reinforced handles on the side.
The cabinet has a removable motherboard tray, which makes benchmarking quick and easy. It has 7 expansion slots, supports up to six 2.5″ HDDs or SSDs with dual X-Dock slots for mounting hot-swappable 3.5″ or 2.5″ drives. On the front panel, it has two USB 3.0 ports, two USB 2.0 ports and audio in & out ports.
