Cooler Master Launches HAF XM Cabinet In India
RoBoGhOsT
Perambulating
Galvanizer
Cooler master has launched HAF (High Air Flow ) XM mid-tower enthusiast grade chassis in India , the mid tower version of its popular HAF X cabinet .
The cabinet measures 252 x 530 x 579 mm and weighs about 10.5kg . It has three 5.25" drive bays and eight 3.5" drive bays (that include two hot-swap bays with removable SATA backplate) . It has bottom mount for power supply . The interiors are full black .
It comes with one front red LED-lot 200mm fan , two top 200mm fans , two side panel 140mm fans and one rear 140mm fan .
Front panel has two USB 3.0 , two USB 2.0 ports and audio IO jacks .
The HAF XM supports full ATX and E-ATX as well as MATX motherboards . It has 8+1 expansion slots , allowing the use of bottommost slot to install dual slot graphics cards .
The chassis is launched at an MRP of Rs 12,299 , however actual street prices are expected to be lower .
Source
