ranjan2001
I had to recently change the PSU hence I bought coolermaster from SMC International, nehru place delhi
I got Cooler Master GX-450W PSU
GX-450W - Cooler Master - Leading Provider of Computer Case | Cooler | Power Supply
I have 4 years old & 1 yr old, 2 APC UPS which have been working fine but after changing the PSU I hear a interference noise from PSU on boot up (apc battery checkup) & then when the current goes off & the computer is running on UPS its continuous interference for all the time which is quite irritating.
I read the review here it mentioned Cooler Master GX-450W PSU - BayReviews
Could this be the problem?
This is the APC UPS which I have, another one is 1100va ups both are having the same issue.
APC Back-UPS 800VA, 230V
Can some one point the source of the problem, I called the APC guys they came & checked the ups its fine, I got the battery changed even then this problem exist, there seems to be some incompatibility among UPS & PSU.
Underneath the blades of the fan you can see the efficient transformer and double layer EMI filter inside the power supply. The extra protection from outside electromagnetic interference limits the exposure to noise and static that other power supplies just let through.
