Cordless Phone Battery Purchase :Need Battery
RajeshJ
Inactive
Explorer
Phone : MDL : WT-3390
Battery Pic uploaded : its Ni-Ca 3.6V 280mah
Kindly show me a site from which i can buy this battery , cant find any local shop seling this
[warp]
[/warp]
The photo angle is not right - unable to guess the height of the battery. I presume it is 2/3rd the size of AA ( pen-torch cell ).
Here is a close match, but you will have to reuse the connecting pin from original battery.
http://www.shopclues.com/cordless-phone-battery-3-x-2-3-aa-3.6-v-300-ma-mah-ni-cd-envie-1.html
Note: The seller has a fulfill Rate of only 67% and no "Cash on Delivery option", not a good one according to me.
Cant find any local shop seling this
If you can find a cordless phone repair shop, they will assemble you one. That is, solder 3 nos 1.2v ni-cd cells in series and tape them together to form a 3.6v battery. Again, they will reuse the connecting pin from the original battery.
The local shop maybe able to help you, but could you post a proper image of the battery? Also check ebay.com etc.
