Corsair Announces AX1200i - World's Most Advanced Power Supply
RoBoGhOsT
Perambulating
Galvanizer
Corsair has announced 'World's Most Advanced' power supply at Computex , Corsair AX1200i which features Corsair Link technology which provides enthusiasts with real time display of information from the power supply .
It is built upon the AX1200's modular power supply to reach 80 plus platinum certification , in addition it has digitally controlled power circuitry which helps to provide stable voltages and low ripple and noise . The power supply offers efficiency up to 92% .
The Link based user interface allows users to communicate with and configure the AX1200i from a PC using a standard USB connection. The Corsair Link software has various tabs which display data from PSU .
There is a dedicated Power tab for precise monitoring and control over your AX1200i PSU , this tab shows information like efficiency , power in , power out , voltages etc .
Code:
There is a System Tab which shows highly detailed overview of the system , like temperatures , fan speeds , CPU cooler temp , pump speeds etc .
The Corsair AX1200i has most of the original features of the AX1200 but it also brings in some exciting new technology and features.
Feature List
  • Digital Signal Processor (DSP) for delivering extremely clean, efficient power with real-time adjustments.
  • Corsair Linkâ„¢ Integration for monitoring and adjustment of performance, noise, and OCP settings.
  • 80 PLUS® Platinum Efficiency for lower power usage and energy costs.
  • Fanless operation at low loads, for outstanding noise reduiction.
  • 140mm thermally controlled double-ball bearing fan spins up as needed.
  • Fully Modular low profile cables for easy installation and less clutter.
  • Engineered to meet maximum power output at a server-grade 50C temperature rating.
  • Self-test switch to determine PSU functionality even before installation.
The Corsair AX1200i will retail starting from August , price will be announced upon launch . It will come backed by 7 year warranty .
Source
