Corsair has announceds its new high performance micro-ATX chassis - Obsidian 350D.
Like the other models in Obsidian series , the 350D comes with black brushed aluminium styling. It is compact chassis but with lots of room inside for high performance builds. It can accomodate Micro ATX and Mini ITX motherboards, has five fan mounts, native 2.5" SSD cage and offers tool-free installation.
Specs and features -
The Obsidian 350D will be priced at US $99.99 for the solid side panel version and $109.99 for the windowed version. It will be available starting from May.
- Brushed Aluminum Front Panel
- Elegant, flush mounted windowed side panel
- SLI / Cross Fire ready
- Five Expansion Slots
- Two 2.5”, two 3.5”, and two 5.25” tool free drive bays.
- Modular 2.5” SSD cage
- Front 140mm and rear 120mm cooling fans. Room for up to five fans total.
- Direct Airflow Path from front cooling fan to GPUs.
- Maximum ATX PSU length 180mm
- Maximum GPU length 380mm
- Maximum CPU Cooler Height 160mm
- Room for two 240mm radiators (top, front)
- Dual USB 3.0 ports
