Corsair Graphite Series 600T ATX Mid Tower Cabinet
mediahome.in
Inactive
Contributor
Feedback: +185 / =0 / -2
Building a Great-Looking, High Performance System Has Never Been Easier :
The Graphite Seriesâ„¢ 600T makes it easy to build a world-class gaming system. With excellent cooling from the dual 200mm fans, eight PCI-E expansion slots to accommodate multiple graphics cards, and plenty of room for large, power-hungry components, the Graphite Series 600T can handle just about anything you can throw at it.
Mid-Tower Size, Full-Tower Features :
The Graphite Series 600T is a mid-tower in height, but inside it’s positively cavernous. Easily accommodate even the longest graphics cards in the industry due to the reconfigurable hard drive bays. The increased space behind the motherboard tray allows clean, uncluttered cable routing. Up to six hard drive caddies, each of which can accommodate SSDs and standard mechanical disks, sit below the four 5.25" tool-free optical drive bays. If that weren’t enough, you can remove the top panel 200mm fan and install a 240mm radiator and dual 120mm fans for a quick watercooling upgrade.
Features for Builders :
Corsair innovated cable routing with the Obsidian Seriesâ„¢ cases, and the Graphite Series features the same ingenious design. Pre-cut holes in the motherboard tray with rubber grommets and plenty of room behind the motherboard to route cables for a clean, uncluttered interior. The optical drive bays are tool-free, the side panels easily detach with the built-in latch mechanisms, and the integrated fan controller allows you to choose between quiet operation or maximum cooling performance.
Features include :
  • Twin 200mm cooling fans with white LEDs for excellent cooling
  • Eight expansion slots provides you flexibility for multiple graphics card solutions
  • Unique cable routing holes guarantees you a clean and clutter-free installation
  • Integrated fan controller, for up to four fans, gives you the choice of noise vs. performance
  • Tool-free optical drive installation makes building your system faster than ever
  • CPU backplate cutout makes upgrading your CPU heatsink easy
  • 2.5†and 3.5†hard drive compatibility for up to 6 drives — straight out of the box!
  • Two year warranty with Corsair’s world-class customer service and technical support
Specifications :
Dimensions|20" (H) x 23.3" (L) x 10.4" (W) - (507mm x 592mm x 265mm)
Material|Steel structure with molded ABS plastic accent pieces
Color|Graphite Grey and Black
Model|CC600T
Drive Bays|(x4) 5.25"
|(x6) 3.5"/2.5" Drive Caddies
Cooling|(x2) 200mm Fans w/White LEDs
|(x1) 120mm Fan
Expansion Slots|8
Motherboard|ATX, mATX
Front I/O|(x4) USB 2.0
|(x1) USB 3.0
|(x1) IEEE1394
|(x1) Headphone, (x1) MIC
Power Supply|ATX (not included)
Reviews :
Corsair Graphite 600T Mid Tower Case Video Review
Corsair Obsidian 700D Case Review - Introduction
HEXUS.net - Review :: Corsair Obsidian Series 700D: more than a case of déjà vu? : Page - 1/6
Corsair Obsidian 800D - Bjorn3D.com
Corsair Graphite Series 600T Review - Overclockers Club
Cost - Rs. 10000 Shipped
To Order Visit :
