Witcher
Hi Guys
I recently installed Corsair H60 2013 edition liquid cooler on my Rig with radiator fan blowing air from outside onto radiator at back of case.
Before Overclocking , with stock settings on proccy , I ran stress test with prime95 software , I am getting following temperatures at idle and load :
Idle : 34-36 C
Load : 72-74 C
individual core temps varying a lot ...........Core 0 temp is around 62 and others core 2 & 4 are at 70 C at full load.
Ambient Temperature should be around 26-30 C
These readings were almost similar to intel stock cooler. Now i am worried abt overclocking more .
I have used preapplied TIM .
My Config:
NZXT Gamma with 4 fans
1 bottom front intake 60-80 CFM
1 botton side intake 50 CFM
1 radiator fan back intake 60 CFM
2 top exhuast outtake (90 CFM + 60 CFM)
All fans are 120 mm LED Coooler master or nzxt fans
Intel i5 3570 K
Asrock z77 extreme 4
Radeon HD 7870 Tahiti LE
8 GB samsung RAM
1 SSD + 3HDD combo
Corsair TX 650V2
Are these temp normal or I should Reapply TIM ? ( I have Noctua NT-H1 tube lying around ....)
Is my Case Fan intake / outake configuration correct ? I am trying to avoid dust in my case and create positive air flow. ?
Also Need some Beginners Overclocking advice for my rig.?
Thanks
Witcher
Idle : 34-36 C
Load : 72-74 C
My Config:
Intel i5 3570 K
8 GB samsung RAM
1 SSD + 3HDD combo
Corsair TX 650V2
Thanks
Witcher
