Intel C2D E6600 @ 3.6Ghz + Asus P5B Deluxe BIOS 0711
Is this best combo for Core2???
Is something better round the corner (december)?
->Have 70,000k for a CPU, MOBO, Ram (atleast 2 gb), Graphic card (dx10 a must....so just tell how much cash to save up), Cabinet(one wid plenty of Upgrade Options...do any screwless cases exist?), HD (atleast 250 gb)
->And what's the status wid AMD's Quad cores? Quad cores do sound gud for 3d and editing but seems they won't do much gud till Yorkshire or whatever the next Quad core series is called come out and make them cheaper.
Required for
->3D (Maya & Max)
->Vid editing
->Digital Painting
->Movie ripping
->Mass Downloading
->Gaming for course
Currently thinking of
->Intel C2D E6600 @ 3.6Ghz + Asus P5B Deluxe BIOS 0711 (since most ppl on Te have it...plz suggest if something better avail.)
->Corsair ram....if that's avail. in delhi
->No idea on HD & Cabinet....
->How much cash to save for a Dx10 card?
So what should i go for..............
- CPU & MOBO = ?
- Ram = ?
- HD & Cabinet = ?
- Graphic Card = Cash to save basically
- External HD (atleast 60 gb) = ?
- Should I OC?...what are the safety measures should i take?
Will be doing Art practice & some freelancing work.....gaming, ripping movies and lots of other shit, basically want to build a monster rig. And will be glad if ppl can suggest the aditional components that can be helpful.
ps- sorry for being so confusing
Required for
->3D (Maya & Max)
->Vid editing
->Digital Painting
->Movie ripping
->Mass Downloading
->Gaming for course
- CPU & MOBO = ?
- Ram = ?
- HD & Cabinet = ?
