Critical Kernel-Power cause system to directly restart without BSOD
princeoo7
On a Journey called Life :P
Level J
I am getting no BSOD but direct system restart. how can I check what's wrong?
In Event Viewer, below is what showing:
What to do to fix this?
on crash dump. got the below:
Microsoft (R) Windows Debugger Version 10.0.25200.1003 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\Dragonar\Documents\1x\New folder\031423-10921-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
************* Path validation summary **************
Response Time (ms) Location
Deferred srv*
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 19041 MP (24 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Edition build lab: 19041.1.amd64fre.vb_release.191206-1406
Machine Name:
Kernel base = 0xfffff805`39600000 PsLoadedModuleList = 0xfffff805`3a22a210
Debug session time: Tue Mar 14 11:55:31.295 2023 (UTC + 5:30)
System Uptime: 0 days 0:28:19.276
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
For analysis of this file, run !analyze -v
nt!KeBugCheckEx:
fffff805`399fa090 48894c2408 mov qword ptr [rsp+8],rcx ss:0018:fffff30e`8db17270=0000000000000050
0: kd> !analyze -v
* Bugcheck Analysis *
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except.
Typically the address is just plain bad or it is pointing at freed memory.
Arguments:
Arg1: ffffce89076c40e6, memory referenced.
Arg2: 0000000000000000, X64: bit 0 set if the fault was due to a not-present PTE.
bit 1 is set if the fault was due to a write, clear if a read.
bit 3 is set if the processor decided the fault was due to a corrupted PTE.
bit 4 is set if the fault was due to attempted execute of a no-execute PTE.
- ARM64: bit 1 is set if the fault was due to a write, clear if a read.
bit 3 is set if the fault was due to attempted execute of a no-execute PTE.
Arg3: fffff805693c8000, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000002, (reserved)
Debugging Details:
KEY_VALUES_STRING: 1
Key : AV.Type
Value: Read
Key : Analysis.CPU.mSec
Value: 3296
Key : Analysis.DebugAnalysisManager
Value: Create
Key : Analysis.Elapsed.mSec
Value: 64735
Key : Analysis.IO.Other.Mb
Value: 6
Key : Analysis.IO.Read.Mb
Value: 0
Key : Analysis.IO.Write.Mb
Value: 10
Key : Analysis.Init.CPU.mSec
Value: 452
Key : Analysis.Init.Elapsed.mSec
Value: 9641
Key : Analysis.Memory.CommitPeak.Mb
Value: 95
Key : Bugcheck.Code.DumpHeader
Value: 0x50
Key : Bugcheck.Code.Register
Value: 0x50
Key : WER.OS.Branch
Value: vb_release
Key : WER.OS.Timestamp
Value: 2019-12-06T14:06:00Z
Key : WER.OS.Version
Value: 10.0.19041.1
FILE_IN_CAB: 031423-10921-01.dmp
BUGCHECK_CODE: 50
BUGCHECK_P1: ffffce89076c40e6
BUGCHECK_P2: 0
BUGCHECK_P3: fffff805693c8000
BUGCHECK_P4: 2
READ_ADDRESS: fffff8053a2fa390: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
ffffce89076c40e6
MM_INTERNAL_CODE: 2
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: UsbService64.exe
TRAP_FRAME: fffff30e8db17510 -- (.trap 0xfffff30e8db17510)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000001 rbx=0000000000000000 rcx=ffffce89077668be
rdx=fffffffffff5d828 rsi=0000000000000000 rdi=0000000000000000
rip=fffff805693c8000 rsp=fffff30e8db176a8 rbp=0000000000000000
r8=00000000000000ff r9=0000000000000000 r10=ffffce89076c3f00
r11=ffffce89077667c0 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz na po nc
vuhub+0x8000:
fffff805`693c8000 8a040a mov al,byte ptr [rdx+rcx] ds:ffffce89`076c40e6=??
Resetting default scope
STACK_TEXT:
fffff30e`8db17268 fffff805`39a744bf : 00000000`00000050 ffffce89`076c40e6 00000000`00000000 fffff30e`8db17510 : nt!KeBugCheckEx
fffff30e`8db17270 fffff805`398a4d70 : ffffce88`f999d270 00000000`00000000 fffff30e`8db17590 00000000`00000000 : nt!MiSystemFault+0x1b171f
fffff30e`8db17370 fffff805`39a09bd8 : ffffce88`cd010340 00000000`00000180 ffffce89`07684000 fffff805`39893239 : nt!MmAccessFault+0x400
fffff30e`8db17510 fffff805`693c8000 : fffff805`693c6f74 00000000`0107fb02 00000000`00000001 00000000`000009c8 : nt!KiPageFault+0x358
fffff30e`8db176a8 fffff805`693c6f74 : 00000000`0107fb02 00000000`00000001 00000000`000009c8 00000000`00000000 : vuhub+0x8000
fffff30e`8db176b0 00000000`0107fb02 : 00000000`00000001 00000000`000009c8 00000000`00000000 00000000`00001001 : vuhub+0x6f74
fffff30e`8db176b8 00000000`00000001 : 00000000`000009c8 00000000`00000000 00000000`00001001 00000000`00000fff : 0x107fb02
fffff30e`8db176c0 00000000`000009c8 : 00000000`00000000 00000000`00001001 00000000`00000fff ffffce88`d8225c30 : 0x1
fffff30e`8db176c8 00000000`00000000 : 00000000`00001001 00000000`00000fff ffffce88`d8225c30 ffffce88`fb0b5e00 : 0x9c8
SYMBOL_NAME: vuhub+8000
MODULE_NAME: vuhub
IMAGE_NAME: vuhub.sys
STACK_COMMAND: .cxr; .ecxr ; kb
BUCKET_ID_FUNC_OFFSET: 8000
FAILURE_BUCKET_ID: AV_R_(null)_vuhub!unknown_function
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {12ebcd29-cf03-148e-43c6-4cfdf23dd6dc}
Followup: MachineOwner
Volmgr and NTFS errors usually point to disk errors. And there are also Kernel boot error. Seems the boot sector zone itself have developed bad sectors. The only way is to first backup the data and then check the disk on a working pc for health scans etc.
Only then you can arrive at some decision if the disk is abd and then where to install new os.
You can even mirror the disk to an error-free disk to keep the os and data intact.
It would be better if you provided more info of the platform you're using, any OC/PBO/XMP settings you may have dialled in, and your system specs for better context.
I did a memtest for more than 5 hrs. and its fine with not issue. may be it was a driver thing. updated to 22.4.1 for amd. lets see if this repeat itself!
forgot to ask? Did you disable automatic restart?
Also, you need to setup full or minimal memory dump for analyzing it later.
For me it’s been a while with windows…
lets see :)
I am not able to install WinDbg Preview. Whats wrong with microsoft. can't they just use ChatGPT to fix their $h!t :/
had to use a vpn for same location to download it. kinda of weird thing as a work around.
random popup on restart!
@booo I have updated first post with the output from the dump file. can you check and see if we can fix this?
Page fault in non paged area means it’s badly written driver. You have to uninstall whatever software that installed vuhub and find if they fixed the problem in later versions.
above link says its Eltima Software USB to Ethernet Connector Driver
ASUS router printer driver. Hmm... but why was it access when I was playing COD or Valorant :banghead:
