Laptops DELL INSPIRON R15 N5110 LAPTOP .. USB 3.0 issue .. need help
alive hunter
Contributor
I have a DELL INSPIRON R15 N5110 LAPTOP .. 6 months old.
under warranty.
This Laptop have one USB 3.0 Port.
Now when i connect my WD 3.0 USB Portable HDD (1TB) to the 3.0 port on the laptop, it is not getting detected.
Where as when i connect the same HDD to the 2.0 port on the laptop, it quickly gets detected.
I am not able to figure out the problem???
Wht can i try?? .. or should i post a complaint with DELL???
please suggest..!!
Regards,
AH
U have to contact dell service,... as this might be problem with the hardware..i think they will replace yr motherboard...
