DIY fan control ? . howto?
Raghunandan said:
Thats the correct way to do it. Keep adjusting the pot to the extremes and try it. The fan should be at full speed on one end and not spin at all on the other.
Raghu.
Yes, but only these two extremes with a 4.7k pot and no speed control. For this purpose a simple switch will do.
Its only to verify that that it will work without blowing up the pot. The adjustment can be done after confirming that.
Btw, any idea which shop in SP Road sells molex connectors?
Raghu.
