amlansarma
Beginner
I have solved the voltage fluctuation problem with Dlink GLB 502T using a switch mode power supply adapter instead of dlink supplied adapter.It cost me Rs.250/-.Earlier internet connection used to get disconnected when there is minor change in voltage.Dlink adapter cannot handle this. Using ups does not also helps.But my new made in India adapter can handle voltage change.So no more disconnection.My adapter is
"Oswal SMPS Power Adapter"
Input 100v to 240v
50-60hz
1amp
Out put- can be switched between 3V to12v
Although dlink requires 9V input,I have set adapter to 12V, as setting it to 9V is not working.You can use SMPS adapter with 9V output if you can find.I am satisfied now.Here is some screen shot of my adapter-
Input 100v to 240v
50-60hz
1amp
