DO - Cheapest 120mm Led Case Fan!!
rahul_varma said:
^^no it says UV Led.
Got my stuff, but the LEDs are anything but UV. I was looking for a UV LED fan not normal LED ones :mad: . I think u should make that extra check when someone is specifically asking about a feature in ur products.
That being said, no harm done as a friend has already agreed to buy these and delivery was very prompt. Thanks, I think...
Not UV leds. :O
So only multicoloured. :(
Also, how noisy did you find these Naga sir?? :)
I think you have used Antecs (regular as well as tricools)- how do these compare to an Antec 120x25mm at 2000rpm.
Will pick up a few depending on these decisions. :)
BIKeINSTEIN said:
Not UV leds. :O
They're quite noisy compared to my Antecs and the connectors are two pin so can't lower the speed. I personally prefer fans with 3 or 4 pin connectors so I can manually adjust speed/ noise to my likings.
But the friend who took this off me had no probs with the noise levels, so...
8 - GlacialTech 120mm UV LED - Left in stock
10 -Amigo 120MM UV Led - Left in Stock
Let me know guys if anyone needs one of these
