For 3-3.5 you can get a full set drill + bits etc from skil which is a low cost brand of bosch. The extra money is worth it as chinese knock-offs don't have a good construction leading to lot of error in the drill center line. Effectively they break a lot of bits and no warranty.
First one looks good...but I already got all types of screwdrivers n all other equipments, other than used in drill machine...
Is it worth spending extra 1.2k or Black & Decker will do the job?
get the skill drilling machine 6510. It cost 1150/-, check local shops.. its a bosh owned company
I am using it from an year and its great. The low end torque is excellent. Has both hammer and drill actions http://www.skil.co.in/skil/l0/product/product.php?gpid=2&pid=[DOUBLEPOST=1366565701][/DOUBLEPOST]Let me know if you are from Hyderabad.. I can guide you.
