superczar
I bought a 3rd party USB cable for my Reliance RD2130 (moonlight) to use it for R-connect.
I verified the cable by pluggin it into my laptop and the laptop (Win XP home) instantly recognized the device as a USB-Serial converter. I then happily bought the cable and came back home.
The problem started when I tied to install the drivers. The CD that came along with the cable apparentyly had the drivers (FTDI chipset) which I tried installing but to no avail. Windows always returned an error saying invalid drivers.
I tried downloading the latest drivers from Relianceinfo.com but none seemed to work.
My question now is:
1- If the cable gets recognized by Windows, could it still be defective?
2- the driver CD that came with the cable (it's burnt on a cheap CD) has the drivers that are available on the reliance site. Is it possible that third party cables use a different chipset (than the reliance original cables) and hence the driver mismatch....
I can find out the chipset by taking apart the cable, but then the cable seller won't replace it if it doesn't work even after that.
3- If yes, what are the other possible drivers, and where can I find them? What are the other common chipsets used in USB cables for Reliance cables
Thanks
My question now is:
Thanks
