FS: Tablet ESR ipad pro M1 11 cover, case, Magnetic, detachable front cover. (should work with M1 air and M2 pro 11)
codwapeace
Level E
Feedback: +42 / =0 / -0
Uttarakhand
5 out of 5
  1. Cash
  2. Bank Transfer
Included in cost
None
No
Not required.
Link: https://www.amazon.in/dp/B09KLPS9P5?ref_=cm_sw_r_apin_dp_0WP2TEN081E49XDEBM0C&th=1
Please follow the link for compatibility check with your ipad.
Only used for 1 week.
Should work for M2 pro 11.
The iPad Pro 2022 and the iPad Pro 2021 sport flat-out identical designs. We’re talking genuine spot-the-difference stuff here.
This is evidenced by the fact that both 11-inch and 12.9-inch variants have identical dimensions of 247.6 x 178.5 x 5.9mm and 280.6 x 214.9 x 6.4mm, respectively. It’s the same when it comes to weight, with both 11-inchers weighing 466g, and both 12.9-inchers weighing 682g. You can add the same 3 or 4g for the cellular models too.
In terms of the look of the two generations, well, that’s pretty much the same too. These are the same slim all-aluminum tablets, with the same flat edges. All of which means that any accessories (such as cases) bought for one generation should work perfectly with the next, no matter how tight the tolerances.
