Shripad
ex-Mod
Hello Guys.
I have decided to go ahead with my long planned extreme overclocking project as i have the DFI now which is specifically arranged for this project by guru3d.
My original Plan was to go LN2 cooling. Remember that this is not suppose to be a 24x7 configuration. Rather temp. record setting experiment.
I have access to LN2 so thats no big deal.
But more i am thinking about it more i am becomming unsure if its the way to go.
I think better suited will be a phase change or Dry ice +ethenol or acetone which is much safer to handle compared to LN2.
So anyone having links to technical data, designs regarding this please pitch in with links or your suggestions. I am also searching on the net but if more pople are there a lot more info can be aquired.
There is no fixed time frame on this. Its gona be 1 long project. Also to do test runs i have a barton and a7n8x mobo.
And ya This is not a joke i am perfectly aware that there is gona be damage to components and stuff like that but i am willing to take that chance.
I will maintain a photo log of the entire experiment here and also guru3d.
Planning to start some work from next week.
someone gota do this in India right?
