Check the following stuff in the following order :
1. HDD - you've checked enough your hdd seems ok, confirm using seatools or WD Data LifeGuard Diagnostics Tool. BTW De-fragment the HDD partition where you've installed your game.
2. Drivers(Both GPU as well as Chipset).
3. GPU - This can be a GPU issue too try running some game with 5850 and next with your onboard(assassin creed will be a good try as it works pretty well on your onboard too). Try cleaning the GPU HSF and try again.
4. Remove the UPS you're currently on. Sparking is also known to cause intermittent hangups so check the wiring too.
