vyral_143 Jarvis Staff member Keymaster Dec 6, 2011 #1 Hi, I have got a Arctic Cooler Freezer 7 Ver 2 from my friend. However its fan is not spinning. From where i can buy a new Fan for it ? Regards, Viral
D dOm1naTOr Explorer Dec 6, 2011 #2 Whats the fan screw hole specification? Are they 80mm, 90m or 120mm ? As the fan isnt a standard size, just use a ruler and measure the distance between the center of two non diagonal fan holes, that might help us to recommend a fan
vyral_143 Jarvis Staff member Keymaster Dec 7, 2011 #3 Its stock fan 92mm. Also i dunn get how to remove it from clip holdibg that cooler.
P panther Forerunner Dec 8, 2011 #5 i have a spare one I mean the whole cooler, let me know if you are interested.
