ace_neo
I purchased HP Pavilion dv4-1242tx laptop a week back. I just wanna ask u people that when i connect my my laptop on AC power the fan at bottom spins at full speed when its charging the battery.
But fan speed do not steps down. It remains at that speed unless i disconnect from AC power. On battery fan spins at normal rate but on ac power it blows out air at full speed it does continuously even if i am using laptop in idle mode. I checked out no virus or malware is there in the laptop.
Fan noise is annoying. Is any body facing the same problem or its perfectly normal ??
