thanks for that ! pls PM me your account details then.
and yes, i read the E11 doesnt have much effect on the M50 as the M50 are already pretty bassy headphones. also, another thing is, i have a xonar DX. the M50 would be used mostly with the PC. does any among the E7/E10 actually trump the xonar DX to justify being used with the M50 over the xonar ?!
am considering fiio for the M50 mainly because its a pain to everytime go to the back of my large PC cabinet and disconnect the 5.1 system's cables and connect headphone cable(s) to listen to music. was thinking that with something like this amp, i could somehow connect the amp to my PC through USB and the M50 in turn to the amp. is this really possible ?
thanks !
You are welcome![]()
#Kilroyquasar
The FIio E7/E10 would probably better the Xonar DX especially when used with headphones since they have a better amp . Also you will be able to directly connect the headphone to the device instead of removing all the cables etc . The same can be directly achieved even with your Xonar DX using the front panel headphone out connected to the Xonar DX![]()
I am using Phillips SHP 2700 and does E6 Power up well and works good with these headphones. To what level does this E6 helps. Plain english would be appreciated![]()
^^ Check PM![]()
Fiio E6 is only an amplifier- it boosts the signals amplitude .Basically useful to get more volume or drive headphones which need more power . If you are using headphones with onboard sound card or a low quality sound card and use Fiio E6 you won't get a huge upgrade in sound quality , but only a boost in volume and maybe slightly more detailing .
Fiio E7,E10 etc are DACs(digital to analog converters) ie-- basically like external sound cards and they will overall enhance your experience with the headphones with better reproduction of sound from your digital files.![]()
Okay thanks for clarifiying. If connect it to Amkette Flash tv HD via RCA to 3.5mm and the sound output is low and same with my mobile. So E6 just amplify the sound but no extra thump right?
@pristinenote
E10 is not a portable amp???
I would love to have it due to bass boost, but I specifically want a portable one as I would like to use it with PMP (iPod touch).
If no, then please let me know which of the above listed amps will provide maximum possible bass along with portability.
Secondly, can you list it on ebay upon request with emi option if you don't mind doing so.![]()
@pristinenote
Ok, please list E11 on ebay with emi option and pm me the link so that I can make the purchase.![]()
