TechNickGamer
Novice
After 1 month of scouring several forums, comparing specs, and wrestling with upgradability issues, again coming back with budget to upgradability factors, finally my beast of a machine is taking its shape. Although, I'm still new in building PC, members here have been very much patient in clarifying everything. All the parts am getting are "Like New" meaning I explored second hand market to fit my budget (had to) and I was in fact shocked to see the PC hardware market available is so huge in many platforms like Discord, other subs and even here in TE and today what I learnt is you need to know the right channels and have a little bit of patient for that specific item if you need it.
(Was able to grab a Current gen GPU with almost 2 years warranty still left )
While the parts are still arriving this Weekend am still in finalising/ buying few other parts to setup the rig. I may have few to follow up
1) I never built a PC myself, can I do it myself with DIY videos or is it a Big no for first timers?
2) I don't have a Wifi on Motherboard, do I get a PCIe Wifi + BT Expansion Card or a Wireless Dongle hat supports Wifi+ BT both be easier whichever has less interruptions.
3) I have 7700XT 12GB GPU and its recommended power is 750W only but I have a 850 Watt PSU (850P 850 Watt 80 Plus Platinum). Is there any Undervolting required if yes how?
4) What are some essential softwares after installing Windows 11 if any ?
5) I have a 1100va UPS but few were suggesting to get a 1500va UPS because 7700XT has high on load and backup is way low?
6) The cabinet am getting also is a pre-owned but its a Full tower, I checked the depth(in mm) of PSU, CPU Cooler and GPU and all seem fitting (in max dimensions). Is there any other way to check if there will be a congestion or Air flow problem before before I finalise it?
Specs -
Amd ryzen-5-7600x
Amd-radeon AMD 7700xt
Noctua NH D15 cooler
ASUS B650 Pro Art motherboard
corsair-vengeance(16x2) 32 GB ram 6000mhz
1 tb Kingston gen 4 SSD
ROG thor 850w plat PSU
Corsair Sapphire 780T Full Tower (still in talks of purchase)
Specs -
Amd ryzen-5-7600x
