FS: Cabinets Fractal Design Ridge MiniITX cabinet (White)
mod_to_odd
Level F
Feedback: +43 / =0 / -0
Mumbai
4 out of 5
  1. Cash
  2. Bank Transfer
Included in cost
Whatever fractal provides in India
Yes
Not using
Hello guys.
I was using this cabinet for my miniITX system but now have shifted the components to my Fractal design R5 for better ease of access and better thermals.
For the Ridge, there was a compromise which had to be made in the airflow as I had to remove the two fans that came preinstalled in the cabinet. So in order to fit the 7800XT Nitro+ (huge card for a miniITX cabinet) in the top compartment of the cabinet, this had to be done.
Condition: It looks amazing and build quality is solid as well. There is a slight curve which you will notice when putting one of the side panels, however once you screw it in then all it needs is a light force to push it in place and that’s it. You may bend the side panel from the middle to sort of straighten it a bit but one should not apply too much force.
Could you just let me know what riser cable it has got? Gen 3 or 4
It comes with the PCIe 4.0 riser card. I had confirmed this before I bought the cabinet.
Just wanted to know. What air cooler did u used in this? How good was the cooling and what proccy.
I was using the Noctua NH-L12 ghost S1 edition cooler and the AMD 7800X3D CPU.
Initially the temps used to be around 76-86 on load but depending on how/where you place the cabinet and whether someone will be using an air conditioner, the temps do go down significantly. I was able to achieve temps hovering between 70-82 on load after experimenting as mentioned above. One can also try to undervolt the CPU which I never did.
