Own a front loader (IFB). IN the last 7 or more years it has functioned well. I bought a front loader specifically for water saving as very little water is required to dip, tumble and rotate and soak cloths, as compared to top loaders, where it needs to be at least half filled with water to do the same. I checked by measuring the water drained during a typical wash and it takes about 50 litres for a full cycle of wash and rinse.
It makes me wonder whether the duration of the spin cycle chosen by Samsung isn't long enough. Bizarre if that was the case.
Samsung and LG both go to around 14 minutes of spin in last round so it must be something else.
In the other thread you mentioned "MirAIe enabled appliances" about Panasonic. Panasonic is a Japanese brand and wouldn't use a Russian term "Mir" in their marketing. The Mirai meaning in Japanese is "future". Probably they think AI future is the in thing now. Some smart ass in advertising or management did the AI caps in Mirai to make it look like two different words.
Yeah, my guess is unbalanced spin
The Panasonic MirAI thing is India only from what I can tell with even the software being developed here.
Any recommendation for 11 or 12 kg front load wahing machine!!!
been looking at this models budget of not more than 50k
1. LG 11kg
2. samsung 12 kg WW12DG5B24AXTL
3. samsung 12 kg WW12DG6B24ASTL
4. or any other brand or model
Please do recommend
or should i go for washer plus dryer combo??
Reactions: rhyxpixta
My brother's family has got a Samsung AI abroad. They thought AI would save them time and effort. In reality, it takes them more time to do things via mobile app. If they are not at home then they have to keep an eye on the running status, as the machine gives them very less time to make another selection before it shuts down after completing the wash. They often need to run another spin cycle as the 1400 one doesn't do a satisfactory job. I think the app should be able to line up two spin cycles back to back. And then you can't power on the machine remotely. I hope the current breed of AI machines don't have these shortcomings. If my machine has Wi-Fi then I should be able to power it on remotely.
I bought the base model of 8kg LG on your recommendation few years back. AI option on appliances back then was gimmicky. My base model LG is quite quick to resume operation if it's interrupted for some reason. AI machines would take their own sweet time to recheck everything. I read such comments in the reviews and I didn't look into AI models further for this reason alone. I think AI models have become more refined lately.
Because of DirectDrive, LG is very quiet. A couple of times my family members told me that I forgot to start the machine after putting in the clothes. For certain cycles, you can't hear much even if you are standing right in front of it!
Not sure which model your brother's family is using but in the SmartThings app, Stay Connect provides full control of the machine if you also enable Smart Control on the machine. It then doesn't turn off the machine and allows you to run any other cycle.
You can also customize each mode to specify the number of cycles, save it and use that mode instead. Also SmartThings supports location and time based cycles, so you can plan the cycle accordingly if you don't want the washed clothes lying in the machine for too long.
I use the machine at 1000 rpm which is also what the technician suggested and I am pretty happy with it in terms of dryness in Mumbai winter conditions.
Reactions: chyawanprash
^that one. 11kg LG models are top end. Only difference is colour
Done
How often in the year will you be using the dryer?
Also a combo machine will exceed your 50k budget limit
since i'm staying alone and in rural area dryer seems very tempting as hanging clothes and then taking off again is a huge problem. atleast 2-3 times in a month dryer will be used. Should i consider seperate dryer!!
Done
was looking at this LG washer/dryer combo FHD1107STB with card offer can get it around 57k. shelling 7k extra i don't mind if dryer is included. As many of you will be aware staying alone and buying 11 kg washing machine is too much but for some its a must as we can wash all big blankets and other big items as in remote rural areas where weather is cold throughout the year.
Bear in mind drying load is lower than than washing load.
Two three times a month should be fine. A seperate dryer should be considered if you need drying more often.
Washing the blanket is fine but you may be able to wash & dry only one at a time depending on its size.
I guess the price has reduced over the years. For 7k more go for it.
If you stick to two or three times a month it should be ok.
You will have to do a service once every 3-4 years to remove any lint that is trapped in the internals as it will reduce drying capacity over time
Thanks alot..have placed the order..hope it gives me peace of mind for atleast 5 years
Let us know how you are finding it.
Says its got Turbowash 360. Will be interested to know how well it works. Short duration but for smaller loads.
Also I wonder if this is an import. Not seen this feature on locally made models as yet.
I think what's happening is the machine isn't getting to 1400 due to imbalance so it spins at a slower speed to protect the machine. The second spin then helps to remove any residual water that would not be there had the first spin actually reached 1400.
Yes, that's a possibility because they haven't checked themselves if their machine is balanced properly.
... Stay Connect provides full control of the machine if you also enable Smart Control on the machine. It then doesn't turn off the machine and allows you to run any other cycle.
Thanks for this tip! I'll ask them to try this.
Reactions: t3chg33k
Didn't mean machine is not levelled properly. I assume that it is. If it's not then the machine might move around during a spin or become more noisy than normal.
I'm talking about the tendency of some loads to be unbalanced when the spin begins. The machine will generally try several times to rebalance the load (LG's typically try 10 times) before giving up and using the lowest spin speed.
So I was suggesting when you finish loading the machine to manually spin the drum to see if you can see any imbalance in the load and then readjust as necessary.
Hey folks ,
Old timer here, first post since forever,
Iam happy to see the forum alive and kicking....
Need a help I am right now in India looking to replace front load washing machine for my old age parents..
I bought Bosch around 15 years ago based on recommendations from this forum..
My requirements are 8kilos, should be durable , should be front load and easy to use.
So please recommend a good washing machine budget is 30 to 40k :)
See the second half of this post
Helps if you can see either model in a showroom before buying
I prefer a clear glass window but you only get the base model with that. Anything higher end means a tinted front door.
Reactions: ubergeek
Thank you so much happy to see you guys still here , I think Gordon is still on my steam friends list lol.
Quick question about direct drive , how good are they ? I went to show room today and the guy was recommending against direct drive as it's hard to repair is that still true ?
Quieter and more control so LG can claim a patent for their 6 motion wash system
I'd be careful believing what that guy says in the future.
Direct drive isn't hard to repair. The reason LG can offer a ten year warranty on the motor is because it's the least likely component out of any to fail.
My LG will be nine years old soon and never needed any service.
It was never true to begin with
I know the general recommendation is for LG over here, so you can go ahead with DD. However, the LG DD is also marketed excessively. For example, it mentions the main benefit as noise and vibration. However, the spin cycle is still recorded above 70 dB in most cases. I purchased a Samsung one recently, so I will not vouch for it at this point, but its spin cycle is around 60 dB (much lower if you use the slient mode which I haven't) and doesn't vibrate much with correct levelling. Also has a 20-year warranty on the motor and 4-year comprehensive warranty.
If the shortest Cottons cycle is used, spin takes up close to half the time. But if the machine is fully loaded as it should be then spin takes up not more than 15% of the total duration. Meaning the most time is spent in the wash cycle. How quiet is Samsung's wash cycle? I bet someone used to an LG would notice how much louder the Samsung is.
None of which you will ever need. The only advantage of a four year warranty is resale value will be better and this is good for migrants. If you don't intend to sell within four years the advantage is superfluous.
