FS: 120mm LED fans
BIKeINSTEIN
Herald
Feedback: +127 / =0 / -0
(1) Item for sale: Antec Tricool 'special black' blue LED 120mm case fan (Antec 900 cabinet original fan)
Specs: 7 heavy, matte-black blades/hub with a translucent white body and three blue LEDs.
1x molex for psu + 1x 3-speed switch. No rpm monitoring.
Seems similar to regular tricool 120mm fans >
120 x 120 x 25.4 mm
DC 12V
RPM 1200 1600 2000
CFM 39 56 79​
dBA 25 28 30
Units: 3 (SOLD)
Reason for sale: Friend is using non-LED fans in his Antec 900 since purchase. :)
Price: Rs.850/- (each) (sold for 700 each to genuine buyers which was the plan anyways :bleh: )
Other comments: As good as new, sparingly used for some hours on day one. :)
Had been kept for the past few months as he was undecided if to sell these or not.
Pics:
Last Fan standing (literally- midair) :rofl: >
Rs.1105/- at 'the IT depot'.
Theitdepot - Antec 120 MM Tricool Case Fan
$22 shipped- on newegg.
Newegg.com - Antec 761345-75024-0 120mm Blue LED Case Fan - Case Fans
Mumbai buyers will be given preference. :)
Please keep discussions on the product/price to another thread elsewhere- you may PM me for the same. :P
Please pardon any delays in replying due to unavoidable circumstances. :ashamed:
PM me with any offers for trade with anything interesting you may have- good non-LED fans, accessories, ...
I will check with my friend if he is interested. :)
Bikey:
I need one fan for attaching to the lower end of the HDD cage, was inspired by Eazy.
Which one of these do you recommend? CFM range I should be looking at?
Or would a plain-Jane 120mm do?
TechHead said:
Bikey:
You should be looking at atleast 55cfm or more (max cfm within your tolerance for noise).
The HDD cage in the chieftec is a bit farther from the mobo than in mini/midtower cases and you may need that extra cfm/pressure/throw for the fan to be of some help to the mobo and gfx.
As far as the HDDs are concerned, even a 40cfm/1200rpm 120mm fan should create enough airflow over the HDDs for cooling them a bit compared to a no fan situation. :)
TechHead said:
Bikey:
[OT]dooood! why are you buying fans! just send mihir to my place, delta wfb-1212M, 72cfm@34dba or else a NMB Minebea 4715KL, 83cfm@37dba. both for 10 bucks :bleh: [/OT]
sorry bikey saaar!
^Ok, cheers.
Our Pune friend is sending over a 92mm fan, will hook it up to the side panel.
120mm.. will call you Tues.. Lamington Road beckons.
Little offtopic:
What is that northbridge cooler into those pictures?
Does that comes with the board or it is an aftermarket product?
If it is an after market product then where can i buy this?
keith_j_snyder2 said:
Little offtopic:
That is the original DFI chipset(southbridge maybe :P) cooler with the top plate removed and fitted with a modded 50mm 11-blade ballbearing fan. :P
If your mobo accepts a similar cooler, you may try getting an Evercool VC-RE or VC-RF as per requirement. :)
BUMP for the beautiful special edition Antec tricools with 3 speed switch and blue LEDs. :D
