41-50k Gaming PC - Some Parts
dinjo
Hell Yeah[Born Critic]
Galvanizer
Q: What is your budget?
40K
Monitor - Dell 2409
CPU - Intel Core i3 3220
Motherboard - GIGABYTE-B75M-D3H
Corsair Vengeance 4GB x2 1600MHz
1X Seagate Barracuda 7200.14 1TB
1X Seagate Barracuda 7200.14 500GB
SMPS - Corsair VX 400W
Monitor
RAM
HDD
MotherBoard ?
CPU
Motherboard ?
GPU
RAM
Yes, no upgrade for some time.
Q: Where will you buy this hardware?
Mumbai
Browsing
Gaming
Nothing like that
All latest games
Desktop - 1920X1080
No
Windows 8.1/Windows 10
Need the upgrade specifically for gaming.
CPU-Intel Core i5 4570 -14500,
Motherboard - Gigabyte B85M-D3H -5500,
GPU - Zotac GTX 960 4GB -18000.
TOTAL - 38,000.
Re-use the existing Corsair Vengeance RAM, Corsair VX PSU, Seagate Barracuda HDD's. Your PSU is more than enough for GTX 960 GPU.OK.
Reactions: johnjoyjoe1979
the above build is good but just wanted to add my 2 cents-
try to get a cheaper core i5 like the 4430 and the 2gb version of the gtx 960 (it can't use the full 4gb anyway)
you should have about 5-6k left over so you can pick up an ssd with that (120gb 850 evo perhaps).
you will still be within the 40k budget and your system will be bottleneck free for a long time.
Alternative suggestion: are you averse to a used cpu?
your platform (b75 chipset) isn't really old enough to consider 'obsolete'.
you could buy a used core i5/i7 3rd gen and just drop it into your current mobo.
with the money saved you could get a better gpu (be advised you will have to get a new psu in that case).
I'm going to get GTX 970 confused between MSI or Zotac , I have Cooler Master Elite Cabinet so just want to make sure it would fit well in the case and no heating issues would happen.Also please make me a strong reason why i should get a new mobo since the one you recommended and one i have are kinda similar infact the one i have is even more expensive one.
For CPU shouldn't i be getting a 3570 @ 3.4Ghz or 4670@3.4Ghz ? and in case i have to change mobo i would also get a new cabinet since thats the only things remains then HDD and RAM can be used from old build , please recommend a appropriate mobo and Cabinet as well
a little hard to understand but i'll try to answer-
zotac has a longer warranty (5 yrs with online registration)
depends entirely on case air flow. some extra fans should take care of excess heat.
a strong reason for a new motherboard is because the lga1155 socket won't support a 4th gen core i5 (lga 1150).
a core i5 3570 can be used on the same b75 board you currently have. the 4670 will need a new mobo.
the performance difference between a 4570 and 4670 is negligible so go with the cheaper one.
why would you have to change the cabinet if you change your mobo? you know it can be removed from the cabinet right?
Ok i have decided that i'll go with full build as I'll sell off my existing PC (might run into heating issues with my cabinet) so i need a new spec with recommendation for Proc , Mobo , PSU and Cabinet
GTX 970 i have already decided so need things around it , I'm not going to do any overclocking so need decent Mobo and Good Cabinet.
gtx 970 is more than 25k
cpu- intel core i5 4440 ~12 to 13k
mobo- asus/gigabyte/msi h81 based board ~4 to 5k
psu- seasonic s12 520w ~5k
cabinet- cooler master elite or antec ASK ~3k
total is well over 50k.
you'll need monitor, keyboard+mouse, hard drive, optical drive and ram from the old system.
alternative,
get the gpu, psu and cabinet now and upgrade the cpu later.
Yes budget changed thought i dont have a definite number but i dont want expensive board and SMPS would take GTX 970 definitely
Alpha was suggesting these boards and CPU
Core i5 469ok
GIGABYTE B85M-D3H / MSi H97M-G43 / GIGABYTE H97M-D3H
Dont need a overclocked board , nor do i need some fancy features , whats the better off between CM 690 II vs NXZT S340 Cabinet ?
If you are going for DVD drives and lots of HDD than CM690 II is best for you and if you are looking for sharp corner design with space for Water cooling than NXZT S340 is nice choice.
As per air flow and cooling performance both will have similar result if same type of Case Fans are used.
Both case comes with two fans. CM offers 140mm led and 120mm fans where as NXZT offers 2 X 120mm V2 Fans and with air filters too.
NXZY offers new design and better cable management. Personally i would go for NXZT case.
@rakesh_sharma23
Actually i have the DVD Writer but i have removed the power as I'm not even using the Drive, which GPU do you recommend Zotac , MSI or Asus ?
It's available for 25k at prime but the cooling is not great on it, also for case confused between cm690 II vs nzxt s340 nzxt looks really clean but seems very small compared to cm 690
For case you should check our corsair 300R side panel version.Lack of optical drive option on s340 might cause problems later but still a very good case.
Corsair 300R is outdated and its spares are not readily available. Go with Corsair SPEC-03 @ 4.3k
S340 is bulky and if you want a similar case you can go with Corsair 450D which is also similarly priced as well...
I got the following PC for gaming in my gaming cafe. Its giving awesome performance for cs go and dota2. Specially Gfx and Ram are great. You can check online for the best prices or the dealer near you. I got in a good rate coz i bought 20 pcs in1 shot.
CPU - i5 4th Gen
GFX - Inno3d Nvidia 750ti 2gb
Ram- Zion Gaming series 8gb
Mb- Biostar B85.
PSU- Antec BP 450
Chasis - Antec x1
HDD- Hitachi.
40K
Monitor - Dell 2409
Monitor
RAM
HDD
MotherBoard ?
CPU
Motherboard ?
GPU
RAM
Mumbai
Browsing
Gaming
Nothing like that
All latest games
Desktop - 1920X1080
No
