Audio General Budget Speaker for VU LED TV 40 Inch Model
sunandoghosh
Dear Friends,
Pls suggest me a good reliable Budget Speaker for VU LED TV 40 Inch Model.
I recently purchased following TV from Flipkart: Vu 102cm (40) Full HD LED TV.
Buy Vu 102cm (40) Full HD LED TV Online with BBD Offers! at best Prices In India
While the TV looks ok has been 1 day s far; the inbuilt sound is not that great it seems.
I have a living room where we view this primarily. The dimension of living room is 4.8 Meter length by 3.2 meter breadth. The TV is placed in middle of long side and we watch at a distance of say about 3 - 4 meters.
Especially the sound is not clear and if i switch off both fans its better audible. However changing (as its reasonably ok) fan is not an option now; P Ls suggest me if buying a speaker for this LED UV TV should serve my purpose of hearing clearly from this tv.
Would not like to go option for replacing TV as rest is fine and am not sure if replacement would give any better sound.
So essentially Kindly suggest SPEAKER in Budget range for VU LED TV
Few attributes after reading many posts:
1. My budget is maximum rs 3000
2. ideally great if it has remote but not essential (not sure even its required)
3. Dont understand bass etc but all i want is clear and loud sound so that news etc can be heard clearly
4. Easy to connect to LED VU TV 40 inch model
5. Presently i have used HDMI cable to connect to Tatasky HD TV box to VU LED TV
Few more questions:
1. Do i need to buy any connectors / cables based on your speaker suggestion?if yes kindly mention
2. Does it make sense to place speakers in sides or backside of rooms (don't prefer though as more work of fitting etc would be required)
KINDLY reply asap please as unable to enjoy TV even after purchase due to lack of better sound clarity Pls.
Thanks in advance.
Are you playing downloaded content through USB? I have the VU 32" TV and the sound is good for me on Airtel HD channels or through Youtube/Netflix on my Xbox 360.
But yeah when I play the downloaded content the sound is not so great.
F&D A110 2.1 Multimedia Speaker
I would have said get Altec Lansing 2.1 speakers (since I'm using them with my Tatasky HD via optical out -> digital to analog convertor), but the treble in them are low. I've heard F&D (another model) and seen that they have realy good treble which is a must since while watching TV channels, the sub's bass part is quite deep and drowns out the mids and treble.
IF you watch HD movies, then get a 5.1 system. The side channels don't come out properly in 2.1 systems even with a digital to analog convertor in between. For a 5.1 system, your budget is not enough.
