PoBoy
Juggernaut
Fan speed control is not really discussed much here, but I'm hoping @cranky will respond.
I'm finally upgrading to Haswell and came across this :
Does that mean that using headers like the SYS_FAN above :
1) Either 4-pin (PWM) fans or 3-pin fans can be used.
2) Fan speed is controlled for 4-pin PWM fans or 3-pin fans using (only) voltage ( i.e PWM if present on the fan is ignored, i.e. there is no advantage in using a PWM fan).
here: http://www.silentpcreview.com/article1363-page6.htmlThe board has a pair of 4-pin PWM fan headers but this is deceiving as the SYS_FAN header can only be controlled via voltage.
