This GO is for the thermal compound offered by Arctic cooling
If you use this you would get 2 degrees lesser temperature than you get after using AS5
Arctic cooling MX-2 Thermal Compound
Application:
CPU, GPU and other applications between power semiconductor components and heat sinks.
High Performance Thermal Compound for the Enthusiast
Turbo MX-2 is a high conductive and low resistance compound for components that require the best thermal dissipation. MX-2 is ideally suited for use in CPU, GPU cooling and other applications between power semiconductor components and heat sinks where high thermal conductivity is critical.
Main Features:
* High Thermal Conductivity
* Low Thermal Resistance
* Non-Electrical Conductive
* Non-Capacitive
* Non-Curing
* Non-Corrosive
* No Bleeding
* Odorless
No Metal Particles
Since the MX-2 compound does not contain any metal particles, there are no problems regarding electrical conductivity and capacitance. In contrast to silver and copper compounds, contact with electrical traces, pins, and leads cannot result in any damage.
Durability
Curing and bleeding of the compound is not possible. In contrast to metal or silicon pastes, this compound does not show decreasing performance over time, does not need to be reapplied and has a durability of at least 8 years.
Performance:
Each tube will cost around 450bux + shipping
Application:
Main Features:
* Non-Capacitive
* Non-Curing
* Non-Corrosive
* No Bleeding
* Odorless
No Metal Particles
Durability
Performance:
