low_bass_makker
Contributor
http://www.techenclave.com/dealers-paradise/delta-fans-120mm-120cfm-high-speed-132361.html
With fan controller delta will be better....
Personally Scythe are far better than Delta. I can't bear 44 db noise that too X 4 ~ 200 db ... I've couple of Sunbeamtech Fan Controller lying around that I'm planning to use.m0h1t said:zander, wont 4x delta be a bit too loud even if you have a a/c next to the cpu?
or you plan turn down the rpm?
zanderzone said:Personally Scythe are far better than Delta. I can't bear 44 db noise that too X 4 ~ 200 db ... I've couple of Sunbeamtech Fan Controller lying around that I'm planning to use.
