Going on Holiday, help needed on batteries
avi
Keymaster
Hi guys, I will be on travelling in my holidays for 1 month, 10 days. I had started earlier thread regarding lappie battery, but seems I need to take care of other devices too.
1) lappie - I have Dell XPS L501x and I am suggested to charge the battery to full, remove it and keep it some place. Right ?
2) iPhone 4 - how ? it has got non user removable battery :@
3) Nook Color - same as above
4) APC UPS - shall I turn it off or keep it for charging for whole period ?
5) Refrigerator - I was suggested to keep it turned on. Correct ?
@mods - please move to correct section.
TIA :D
Charge it to around 40-50% and remove it
Leave the Main ON, but the output off
If you need to leave stuff in the refrigerator, then yes, you need to leave it on, else you can switch it off and save some power
TIA :D
"The message you have entered is too short. Please lengthen your message to at least 10 characters."
General principle for any Li-ion battery is to charge around 40-50% and switch off the device. Heat, deep discharge and full charge hurt the battery the most. Else better still carry the iPhone with you :)
oh just 40-50% ? I was suggested to charge it to full
Guys is it 40-50% charge for iPhone or full charge ?
I will be leaving in few hours.
@aditya - can't take the iPhone with me man :(
