Can anyone suggest me a graphic card with Sound out via HDMI? Is there any?
S santosh86 Disciple Sep 11, 2009 #1 Can anyone suggest me a graphic card with Sound out via HDMI? Is there any?
S santosh86 Disciple Sep 11, 2009 #4 and none of the Nvidia cards have it?? For ATI, which one would you suggest for around Rs.5000
D dOm1naTOr Skilled Sep 11, 2009 #5 4670 512 DDR3 ofcourse. its for 4.4k. You can also opt for slightly less expensive 4650 for 3.3k.
S santosh86 Disciple Sep 11, 2009 #6 thanks man. i'll look up the 4670 on the web. any particular brand? i looked up the xfx site and it only had the DVI version!
N NAV33N Skilled Sep 11, 2009 #8 Nvidia 9800 series & 200 series provides HDMI sound but you need to hook up a cable from your G-card to M/B it comes with the G-Card.
S santosh86 Disciple Sep 11, 2009 #9 that would be alright too since the cable is already provided naveen58 said: Nvidia 9800 series & 200 series provides HDMI sound but you need to hook up a cable from your G-card to M/B it comes with the G-Card. Click to expand...
A anfjavid Skilled Sep 11, 2009 #10 even xfx 9600gt comes with HDMI sound by connecting a cable to mobo mate...
