hgps
Explorer
i bought a HDMI to DVI cable from ebay for Rs.195/- [the one which has 24+1 DVI-D at one end and HDMI at other]
plugged it to my PS3 and LCD HP w1707 then turned it on.
no display
then connected PS3 to my SD TV[composite cables] and LCD [HDMI to dvi]
when i turned on PS3, it showed 'hdmi cable detected do you want to use HDMI output' i selected yes. then TV went black and nothing happened in LCD [ still showing check signal cable]
i tried selecting HDMI from video settings>output but TV goes blank everytime and nothing is displayed on LCD as well
i always use VGA output for my PC. this was first time i used a DVI cable
i cant find out what's the problem. Is there any possibility of faulty cable?
LCD supports HDCP. i googled about it and found many people used it with ps3 and it worked fine just by plugging cable and turning on both ps3 and lcd.
no display
