I keep getting BSODs or freezes randomly say once a week....No dump files are found after the crashes either...
At first, I couldn't find the source of the problem. But now I'm pretty much sure that prob is cauz of the hdd...
The system boots up normally only when i adjust the sata cable. Someone please help. Is it because of a loose cable?
Btw i'm using the cable supplied with the motherboard. is that a problem? cauz a friend of mine who bought his computer bout a week ago is also experiencing the same problem.
And yes... my comp doesn't check the disk for errors after sudden restart. Is the feature switched off? Can it switched on again??
Thanks.
Thanks.
