Spacescreamer
Level H
Hey guys..
I had allocated 30GB for the C: when i installed Win7.
There are other 3 partition as well which have got ample space.
Issue is with the main C: partition. I have been running out of space for quite some time. 2.xx GB used to be the norm generally which itself used to be pretty low. Since past few days that the updates been pushed, the scene is hovering at less than a GB at times as well.
I havent installed anything major apart from the essential stuff.
I thought 30 GB will be good enough for the Win 7 ultimate (64 bit), but the space management is really killing me now.
I have to install some important programs now, but with such low space status.. i dont think it ll be possible.
So pls do tell me what is taking up so much space on the HDD (C: ie)
and how to reclaim decent amount of GB back..
Thanks in advance.
EDIT: Already did checked the C:\windows\temp.. atm nothing more than 120MB.
Thanks in advance.
