Help CS Problem
ultimabasher
Discoverer
got my original cs cds today
i was happy
when i inserted the cd the pc restarted
and when i restarted it and then inserted the cd it again restarted
no error message
it happens with both the cds
what can the be the damn prob :@
how do i install cs if it keeps restarting
dude PM me ur personal ID i have a fix which i received from Steam long time back use that to execute the file for CS it works fine had the same problem with Half Life 2 that i had bought its the steam way of keeping piracy low.
ultimabasher said:
but how can i enter the cd key when the key itself is supposed to be inside the cd
i cant even open the CD
ero where are u :@
CD key is never on the cd.... it is on the leaflet that is provided in the box ;)
do check thoroughly...
had checked it but still i was only able to find one leaflet that siad basic controls of cs 1.6
still ill be doing some R&D when i go home tomorrow
found the cd key
does any one have any other suggestions
i swear i would have sued even the assess of steam for crapping everyday in their toilet had i been user of only genuine games and softs
now the thing i found out is that whenever i insert any cd the pc restarted
fiddled around somewhat and found out that it was nero's winaspi32.dll that was causing the havoc as i had uninstalled nero already
so i just downloaded that shit and put it in my system32 folder and then just restarted my shit and then it wont boot
it will just stick at windows login screen and not go any further
without even a single minute of delay i took out the windows cd and installed new windows :P
now i am playin cs and some other ones too
anyone wanna get pwned :p
my steam ID is jacktheripper01041988
