[HELP] Error while validating XML against XSD using PL SQL
raksrules
Oracle
Hi, i am encountering the following error while trying to validate the XML file against XSD schema using PL SQL.
The XML File and XSD files are stored in two different tables in CLOB type variables.
This is how i am using
Code:
    l_xml_type_0            XMLTYPE;
    l_xml_type              XMLTYPE;
    l_xml_type_0  := XMLTYPE.createxml(l_xml_data);
    l_xml_type    :=   l_xml_type_0.createschemabasedxml(l_xml_schema_name);
    l_xml_type.setschemavalidated(1);
    xmltype.schemavalidate(l_xml_type);
In the above code unit l_xml_data is a CLOB type variable holding the entire XML file
l_xml_schema_name is the XSD name against which validation is the happen. This schema is registered in the database and can be found in ALL_XML_SCHEMAS
The error message i am getting is
Code:
ORA-19030 Method invalid for non-schema based XML Documents
DB Version is 9i
