Budget 0-20k Help finding a mini-PWM to dual PWM splitter
UserRG
I need a mini-PWM to dual fan splitter for deshrouding my GPU like (https://www.aliexpress.com/item/1005001579112907.html or https://www.aliexpress.com/item/1005004452328793.html). Can't order from Aliexpress as they stopped taking Indian cards. Only similar item on Amazon.in is https://www.amazon.in/CRJ-Splitter-Adapter-Sleeved-Graphics/dp/B07T95C68T/ . but it's insanely priced. Usual places like mdcomputers, vedant doesn't have it, would appreciate help from someone with better google-fu than me.
Get a pinout and you should be able to make your own cable with parts online. If you can ship the raw materials to me and are not in a super hurry I can make it for you. (If you don't know soldering yourself, if you do, it should be a simple task)
https://www.amazon.in/dp/B078ZF1K56/ - Found this but description and pics don't match - if you are ready to replace twice before getting refund - this is worth the try for the price they're asking.
Head to any local computer shop, if they have it in spare you can get it for 500 or under 1k.
My go-to local shop had advised to check online, but he's more of a seller than repair shop though.
Noctua fans give splitters with their fans. Just informing.
Thanks, I checked and currently they give 3 normal PWM splitters with each fan (NA-SEC1) , I need a mini-PWM splitter for GPU.
Thanks ! Just bought one, lets see what I get.
I haven't soldered anything before, I would like to give it a try though. Normal PWM splitters are easy to get, so can I change just the the normal pwm end to mini-pwm ?
Well I bought from exactly the same listing. These are the normal Case fan splitters. I bought them knowing that they were for Case fans and not GPU.
Got the order today, it's normal case splitter.
Yup, I thing the mini plug is a 4 pin JST PH connector.
I am confused about the pitch, do i need PH 2mm or ZH 1.5mm. Normal PWM connector is 2mm pitch, so mini PWM should be smaller than that, but I can't measure without opening up the GPU.
