Help for a 80mm case fan
Would like to change the 80mm fan placed on top that came with my NZXT Lexa Blackline case.. was looking for a VFM Blue LED maybe a UV reactive one too within a budget of 500 or lesser..can anyone help me with a few good choices (pretty confused seeing the ones in the dealers thread :huh::huh::huh
Also any suggestions on how to manage the airflow in the cabby,
As of now it is :
FRONT, 1 X 120 mm
REAR, 1 X 120 mm Red LED Fan
SIDE PANEL, 1 X 120mm Red LED
TOP, 1 X 80mm Fan
Since its got a slot for a bottom fan too, was thinking of shifting the top 80mm fan to the bottom so that it can act as an intake fan and throw some air on my GTX 260 but not sure if its the right idea..
Would appreciate ur ideas n suggestions..
CHeers
As of now it is :
FRONT, 1 X 120 mm
TOP, 1 X 80mm Fan
CHeers
