I want to assemble a PC for home use :- Budget without monitor, KB & Mouse (Rs.20,000) - can stretch a bit.
1) AMD Athlon II -X4 -620 or better with similar price range (with onboard graphics)
2) Mother Board with good/prompt service (with capability to add graphics card in FUTURE) (ASUS/ Biostar / Gigabyte / MSI)
Preferred :
• Sideport memory
• HDMI/DVI connectivity (to connect LCD-TV to the PC)
• IDE support (to connect old HDD – not very important)
• Card reader etc..
• Blue tooth support
3) Zebronics Bizli Cabinet (model number) - how many fans inside needed ?
4) Power Supply unit (what make and number)
5) Western Digital Blue 500 GB HDD (Model number)
6) Kingston DDR-III (frequency ??? 1333/1600) Ram.
7) DVD – Combo LG/Samsung
Applications that I will use :
Windows 7 / XP ( 64 bit version) , MS Office and simple games such as need for speed etc..
The above is what I collected from this site! Please suggest the suitable config including processor. Indicative prices.
All material will be purchased (in person) from Lamington Road Mumbai.
Thanks in advance.
Prime AbGB suggested this combination : can you comment please ? prices as on 22/1/2009.
GIGABYTE 785 MUD2H = 5700/-
AMD X4 620= 5200/-
4GBKIT CORSEIAR= 6300/-
CABINET NZXT GAMA= 2000
GIGABYTY 460 SMPS= 2200
Preferred :
• Sideport memory
• Card reader etc..
Thanks in advance.
AMD X4 620= 5200/-
