see. the wifi adapter getting disabled automatically is a very common virus problem.. its been bugging my bros lappy for a long time now.. but i think its just screwed altogether..
as you mentioned you've got 3 HDD's, theres no point just formatting one. as soon as you boot up and windows detects all the HDD's, its gonna copy all the viruses to every drive. .thats why its called a virus.. coz it spreads on its own .like a biological virus.
Now one last step to do before i exhaust all my logic and understanding..
Disconnect the 2 extra HDD's and put em aside. now remove the Cmos battery so that the BIOS is reset again.. now format your primary HDD. .and i mean completely wipe it off. no partitions nothing. just delete all partitions. .no data to be kept.. and format your HDD. quick format is fine.. no need to do thorough formatting. now install windows. and after that, dont install any of the hardware drivers. just plain windows.. and then see what happens.. for how long the computer stays fine..
if it works fine with just windows without any drivers installed , it might be that a certain hardware might be causing issues.. a good chance that it might be your graphics card if you've one otherwise the onboard display adapter.
then what you need to do is install 1 driver at a time, put your comp. under observation, if it works fine, then go ahead with the next driver. this way, if a particular hardware is causing issues you will know as soon as you restart your comp. after installing the driver for that hardware.
plz also try borrowing one of your friends RAM and see if the problem persists. infact try this step before trying the above steps. and also use your RAM on your friends comp. this two way crossing will confirm that if theres a problem related to this area, then whether your RAM is faulty or the RAM slot on your mobo is faulty..
I know all this is exhausting. you might even be thinking whos gonna go through such headache..but if i am not able to find a solution to a problem upfront, this is how i go about analyzing and eliminating possibilities to keep getting closer to the prob.
even if your prob. is unrepairable, doing all this will atleast increase your understanding for future probs. and you will be able to better guess what might be causing a problem.
i mentioned the RAM thing again because sometimes it might happen that the RAM might be malfunctioning after some time due to heat or any other issue..
