Laptops [HELP] Laptop boots and shutdowns immediately
raksrules
Oracle
I have this Toshiba laptop which i have mentioned before. It had got this bad sector HDD and i went ahead to install windows 7 on this machine.
Initially while installing, the setup mentioned that the harddisk will fail and advised me not to install windows on this machine. But still i forced it to install the OS.
Now i have few drivers already available for this laptop (vista actually) but on installing the OS i found that most of the drivers came itself. Then there was this one EXE file in my drivers folder named "PSLC8-PSLE8-180-WIN.exe" which is supposedly some BIOS flashing thing. My toshiba satellite laptop is of model no. PSLC8C-01N019 so i know i think whenever i had downloaded this was for this laptop only (name was ). The flashing thing did not allow any intervention and i had to flash it (since i had already executed the file). It went fine and OS restarted but now it refused to boot into windows and gave me option to repair or start windows normally. When doing repair, it gave me a window saying
A hard disk problem is preventing windows from starting
There was a pop up also with label "Startup Repair" and under View problem details i said.
Problem Signature:
Problem Event Name:StartupRepairOffline
Problem signature 01: 6.1.7600.16385
problem signature 02: 6.1.7600.16385
problem signature 03: unknown
problem signature 04: 1
problem signature 05: AutoFailover
problem signature 06: 1
problem signature 07: bad disk
OS Version: 6.1.7600.2.0.0.256.1
Locale ID 1033
I did a cancel on this screen and there was this hyperlink type thing which said "View Diagnostic and repair details" and when i clicked that it gave me
Startup Repair diagnosis and repair log
Number of repair attempts: 1
Session details
System Disk = \Device\Harddisk0
Windows directory = D:Windows
AutoCheck Run = 0
Number of root causes = 1
Test Perfprmed:
Name: Check for Updates
Result: Completed successfully. Error code = 0x0
Time taken = 16 ms
Test Performed:
Name: System disk test
Time taken = 0 ms
Test Performed:
Name: Disk failure diagnosis
Time taken = 109 ms
Root cause found:
Bad hard disk:
Now the main question is that all was working well before when vista was installed and only after windows 7 was installed this thing came in. From whatever the logs say, it looks like HDD failed which was very well expected.
I have a strong feeling that BIOS update went fine since after computer start i am able to get into BIOS and also am able to see it is the newer version.
There is this link i found with same issue but not of much help.
Has my HDD failing in co-incidence with installation on windows 7 or is Win 7 is intolerant towards bad hdd and renders the laptop useless ?
I am now trying to install windows vista again and see if my laptop comes back to life :(
HERE IS AN UPDATE......
I again reinstalled Windows 7 on the same laptop and the installation went fine and i am able to boot in win 7 on this laptop :S
So i think it is just that the HDD is many a times reporting the failure stuff and not allowing the boot to happen thus rendering the laptop useless for that time period.
Btw how do i confirm that the drivers were automatically installed ?? Device manager ??
Under device manager i am able to see
Display Adapters -> ATI radeon 3100 Graphics
Network Adapters -> Atheros AR5007EG Wireless network adapter
Realtek RTL8102E/RTL8103E Family PCI-E Fast ethernet NIC
Processor for some reason shows two entries as
AMD Athlon (tm) X2 Dual Core QL 60
Under sound, video and game controllers it says "High definition audio device" (need to install any drivers ???)
if there is a question mark against the hardware in the device manager list then you have to install driver...else you are good to go..
If there isn't unusual mark against any hardware then you have no issue.
But i suggest you to install the drives that came with the laptop. Those might have updated version, also they contains tweaking application within them (e.g.: audio control panal etc.) Also update your gpu driver to the latest one for better performance and stability.
Finally get a new HDD:)
Faulty HDD coincidently popup with the Windows7 setup. Other than HDD replacement whatever you do will end up in trouble. Don't waste time in drivers, software installation, take backup of data then replace HDD.
it may be a case of windows tried to install itself on one of the bad sectors so you might have got into trouble the last time.
suggestion try to change to a newer disk and do not work on the soon to dead hard disk.
buy a newer hard disk and wait endlessly for WD to get you a replacement.:hap5:
^^Yeah man those WD people have not scheduled any pickup :@
And again the laptop has died which i expected. Now only when my replacement HDD comes i will be able to install another copy of the windows 7 on that HDD.
I have already taken backup of whatever i could, even when i tried copying i got many a times CRC errors and "cannot read from source disk" errors . My drive will be dissected now :P
Any way i can try my luck with Hitachi (this current HDD is of hitachi) and tell them that i have a 2.5" HDD which i need to be replaced without saying that i had installed it in laptop.
^^ i think there is an option of sending them the faulty HDD using their account for the courier... am not sure but you might search their site.
^^Yes they have this facility that i can send the HDD under their account but the local bluedart office mentions that they need a mail from flextronics directed to Bluedart with pickup request and those dumb flextronics guy mailed 'ME' saying that i can ship using bluedart (no cced to bluedart)
This is the reply they send ONLY TO ME
See...No mail to bluedart :@
From: Customercare WD <Customercare.wd@in.flextronics.com>
To: XXXXXXXXXXXXXXXXXXXXXXXXX
Sent: Wed, May 4, 2011 1:11:28 PM
Subject: RE: RMA# 8X66XX2X - TO-PAY Request
Hi
As per discussion you can send the shipment through blue dart in to-pay basis. We will pay here and receive the same.
Our address:
Flextronics technology ( India ) Pvt ltd.
SVR Fortune, No-70-A
Electronic city, Hosur road
Banglore-560110
Thanks & Regards,
Girish.
Desk: 080-30801335
Mobile: +91-9686190776
Mail: customercare.wd@in.flextronics.com
'Creating value that increases customer competitiveness'
