I have recently purchased Corsair 400R
My Rig:
i7 2600k
gigabyte z68xp-ud3
seasonic s12ii 620 w
16 gb corsair
OS: Lion
If you see the above link of Corsair 400r cabinet, there are top and side openings for fixing 4 120mm fans. Front has 2 fans pushing cold air inside, but there is a air filter preventing dust. PSU also has a dust filter and is fixed at bottom of the cabinet to fetch cold air.
Rear Fan (120 mm) throws hot air outside so no such dust issues..
I am worried about the top and side panel fan openings, which is empty as i have not fixed more fans there. I do not see any need. But if i do not put fans there, dust is entering everyday. I am worried.
Can you guys suggest anything?
Besides, can i close these extra fan openings with paper or some blocking material, if it does not harm the PC?
please suggest..
thanks
My Rig:
i7 2600k
gigabyte z68xp-ud3
16 gb corsair
OS: Lion
please suggest..
thanks
