Help Me build a workhorse for 60-75k
laugh
Q: What is your budget?
60-75K
dell Latituded520
Samsung p2350
samsung p2350
CPU - i7930
Motherboard - ?
GPU -
Cabinet- ?
Psu- ?
Will keep it as it is for few years.
Mumbai/online
No
Multitasking
Running CPU hungry Programs
Movies
no
Non-Gamer
1920*1080. I will be running a two monitor setup. Have one samsung p2350. Will get one more.
No
Windows 7 64 bit, xp
techno_guy said:
check it
http://www.techenclave.com/pc-buyin...an-technology-community-pc-buying-169928.html
if you want to do any changes in that config then take advice of forum members
Techno guy. I believe no configurations fits my needs. My needs are as below
2.I am going for a dual monitor setup (I already have one samsung2350 and I am looking to buy another one).
2. I am not sure whether its possible but I am looking to go for raid 1 with a lower capacity HDD for the seondary HDD.
Alternatively I can go for SSD for OS and Apps and use the normal HDD to store media files and use it as raid. (I am not sure whether it's possible)
3. I don't game and I don't use photoshop or CAD. So a graphic card which supports DUAL monitor setup will suffice.
4. Desktop will be running 24*7 and there will be no air conditioning.
5. I don't need fancy cabinets, something which goes well with the overall desktop will do.
Ok Bru you were the one who asked for suggestion, he gives you a response and you Zerg him huh ok for your config
Core i7 930
Gigabyte GA-X58A-UD9
Corsair, G Skill, Kingston, ( any respectable brand of your discretion ) - 12 GB kit
ATi Radeon Hd 5470
for RAID it is recommended you don't get the hard disks of different capacities
Starting price of any Solid State Drive is Rs 8000 and all suffer from the issue of data redundancy after a certain time ~ data loss
Power Supply Cooler Master Silent Pro 600 W
Cabinet NZXT Gamma
Now make up your mind hope this helps and don't stomp the people who try to help you
Thank You Alpha for your suggestion. Really appreciate it. I checked the thread before creating this one and had a look once more when techno guy suggested to have a relook and stated the fact.
Core i7 930 =14300
Gigabyte GA-X58A-UD9 =36500
Corsair, G Skill, Kingston, ( any respectable brand of your discretion ) - 12 GB kit= 18000
ATi Radeon Hd 5470 =I cannot find price, I am assuming 7500
Power Supply Cooler Master Silent Pro 600 W =Cannot find price and I am going to assume its 7000
Cabinet NZXT Gamma =2000
Total works out to 85300. Can You downgrade few components and so that the price is less than 60-75k
If I have to pay a 50% premium for 10% performance increase I will not :)
Thank You.
Since that is the case I would recommend
Gigabyte GA X58A UD5 or UDR 3
Go for 8 GB of the same RAM but try to retain in multiple of 6 as far as possible
Price of the graphics card ~ 5K+
Price of the silent pro 600 W should not be more than 6.5K or try for the FSP Blue Storm Pro 500 W ( 80+ bronze standard efficiency ) around 6K
Hope this further clarifies :), thanks for the rep
laugh said:
I contacted few te dealers and phoenix offered me these for the ram and motherboard combo. Your views :)
http://www.techenclave.com/dealers-paradise/dfi-dk-x58-t3eh6-sli-xfire-171230.html
I am not really sure about DFI's RMA service in India.
So i would recomment
MSI X58 Pro-E ~ 10.4k
Corsair XMS3 6GB kit CL9 ~ 8.2k
This works out be even more cheaper :)
There is no Desktop ATI card with the name HD5470. The HD5670 512MB GDDR5 costs 5.2k and will suffice for movies and casual gaming needs. I am not sure whehter the HD5670 dual DVI outputs are availble in the market. If not then u would have to use VGA for one monitor and HDMI/DVI for the other.
Scale back on the card further get the HD 5450 should be around 5 K mark.
Motherboard whichever you feel is better try reading and comparing reviews of both boards will make the situ more clear.
about the wrong info about the card My bad Bru :)
