girish925
hello guys my system build is almost complete will be assembling it tom its a i5 10400 paired with b460 mobo
need to finalize the cpu cooler as i dont want to use intel stock cooler which would be good value and decent cooling
local price for coolermaster 410r - Rs 1700 deepcool gammaxx gte v2 - 2400
Deepcool GAMMAXX GTE V2 RGB 120mm CPU Air Cooler (DP-MCH4-GMX-GTEV2)
Deepcool GAMMAXX GTE V2 RGB | 120mm Performance CPU Cooler - DP-MCH4-GMX-GTE - Upgraded and Better Heatpipes - PWM RGB Fans - Better Heat Dissipation...
mdcomputers.in
Cooler Master Hyper 410R RGB | 92mm Air Cooler | Mdcomputers.in
Cooler Master Hyper 410R RGB | 92mm RED Led CPU Cooler | RR-H410-20PK-R1 - PWM Fan - Easy to install - Direct Heat pipe contact - Versatile Mounting
mdcomputers.in
