I would be starting with this build once I am done shifting to Hyderabad early next month (Feb).
What I would be retaining from my current build
Corsair HX1000 PSU
X-Fi Titanium Fata1ty Champion
Hard Drives
HP DVD Writer
Other Misc stuff like Headphones etc.
The Rest of the stuff from my existing build would be used for a second rig which would be used by my sister.
What I propose to buy new
CPU + Motherboard:
Goal is 4GHz Overclock and great multi-threaded performance. Virtualization performance in VirutalBox/VMWare is also important. Motherboard should be feature rich with USB3/SATA3 support. There is a good chance that I would do Multi GPU if I don't do it right of the bat. Lastly, the Mobo should not cost an arm and a leg on its own. Intended budget for combo is roughly 30k
Options I am looking at
Phenom X6 1090T/1100T + Good 890FX based Mobo.
Core i7 950 + Good X58 Mobo (Considering Asus Sabertooth X58)
Core i7 2600K/Core i5 2500K + Good P67 Mobo.
Is it a good idea to go for the P67 platform (Sandy Bridge) over X58? One of my main gripes with P67 is that it cannot do 2 x PCIe X16 like the X58. Would it be good enough for a SLI/Crossfire config with the latest GPUs?
CPU Cooling solution:
Goal is safe operation of CPU at 4GHz even in hot summer conditions. However to be honest, I am kind of fed up with uber large traditional HSFs that take up a lot of space in the CPU area. So I am seriously considering maintenance free water cooling solutions like the Cosair H70. What do you guy's think. Is it a good option or should I stick to one of the traditional HSF's. If so which one? Mind you I am not so concerned about the noise as about the bulk of these things.
RAM:
I am completely out of touch with the DDR3 RAM arena. I would be going for 6/8/12 GB RAM depending on Triple/Dual channel platform I get. I am not too keen on RAM overclocking as it didn't turn out well for me in the past. A kit that works well at around 1600MHz is fine for me.
Display
Should have 1080p and above resolutions. Size 23" and above, but would prefer something around 26/27". Would prefer IPS Panel's, but not willing to spend insanely huge premiums for them at the moment. Even a good TN Panel is fine. Must have a decent number of connectivity options (DVI + 2 HDMI at the very least). Currently considering a max budget of around 25~26k.
Benq M2700HD (27")
Dell U2311 (23")
Need opinion on Benq M2700HD. Also suggest any other good displays in and around that range.
Graphics Card:
Gaming at 1080p and above. Budget is 30k. Would not go for more than 35k at the moment. Considering the following options
- Single GTX580
- Single HD6970 (with intention of adding another later)
- Single GTX570 (with intention of adding another later)
- Dual HD6870 in Crossfire
- Dual HD6950 in Crossfire
Currently I am more inclined towards single GTX580 and Dual HD6870/HD6950 solutions.
Cabinet:
Looking for a super tower case that is more roomier than my CM Stacker 830 Evo. Would prefer one with a Removable Motherboard tray and weight less than 13 Kg, but willing to compromise on these for a really good cabinet. Should be well ventilated and suited for Air cooling.
Was interested by the specs of Xigmatek Elysium, but the same is not in the market yet. I sent a mail to Tony of Xigmatek and got reply that info would be revealed at best in two weeks more. Other than that I am looking at
- CM HAF-X
- Lian Li PC-P80 (Outdated design and not available in India)
- Thermaltake Armor+/Xaser VI (Too Heavy and not sure how much roomier than Stacker 830)
Have half a mind to import one of those Mountain mods custom built cases like the U2UFO. However they too are costly and not sure how importing them will work out.
Corsair HX1000 PSU
Hard Drives
HP DVD Writer
CPU + Motherboard:
RAM:
Display
Benq M2700HD (27")
Dell U2311 (23")
Graphics Card:
- Single GTX580
Cabinet:
- CM HAF-X
